Loud noise from underneath
Jimmyheaters
Minnesota
I have a 1989 ford bronco and when I got it was making a loud noise when coming to a stop so I assumed it was my brakes because I also needed them done and I did get them done but the loud noise is still present when I am just starting to move and when I come to a stop and I am wondering what it could be
Yo Jimmyheaters,
See Noise, Vibration and Harshness by Ford @ http://www.diesel-dave.com/vehic/manual/stj/stjs040l.htm
Excerpt for example;
Section 00-04: Noise, Vibration and Harshness
1996 F-150, F-250, F-350, Bronco and F-Super Duty Workshop Manual​
DIAGNOSIS AND TESTING
Symptom Charts​
ROAD TEST DIAGNOSIS
ConditionPossible SourceAction
  • Noise Is the Same on Drive or Coast
  • Road noise.
  • Vehicle OK.
  • Tire noise.
  • Front wheel bearing noise.
  • INSPECT/REPLACE front wheel bearings. REFER to appropriate section in Group 04 (2-wheel drive) or Group 05 (4-wheel drive).
  • Differential bearings.
  • INSPECT differential bearings. REFER to appropriate section in Group 05.
  • Pinion bearings.
  • INSPECT pinion bearings. REFER to appropriate section in Group 05.
  • Noise Changes with Type of Road Surface
  • Road noise.
  • Vehicle OK.
  • Tire noise.
  • Noise Tone Lowers As Vehicle Speed Lowers
  • Tire noise.
  • Driveline noise.
  • INSPECT driveshaft, U-joints and rear axle universal joint ******. REFER to Section 05-00. For removal of driveshaft, REFER to Section 05-01.
  • Similar Noise Is Produced with Vehicle Standing or Driving
  • Accessory noise.
  • Transmission noise.
  • INSPECT transmission and mount. REFER to appropriate section in Group 07.
  • Engine noise.
  • Noise Most Pronounced on Turns
  • Front or rear wheel bearings.
  • INSPECT front/rear wheel bearings. REFER to appropriate section in Group 04 (2-wheel drive) or Group 05 (4-wheel drive) for front and rear wheel bearings.
  • Differential side gears and pinion gears.
  • INSPECT/REPLACE faulty gears or clutch packs (if equipped with limited slip). REFER to appropriate section in Group 05.
  • Drive Noise, Coast Noise
  • Wheel bearings.
  • INSPECT front/rear wheel bearings. REFER to appropriate section in Group 04 for front wheel bearings on 4x2 vehicles or Group 05 for front and rear wheel bearings on 4x4 vehicles.
  • Ring and pinion gear.
  • PERFORM Pinpoint Test G. INSPECT ring and pinion gear. REFER to appropriate section in Group 05.
  • Clunk on Acceleration or Deceleration
  • Inoperative throttle damper.
  • REFER to appropriate section in Group 03.
  • Loose suspension components.
  • INSPECT suspension. REFER to appropriate section in Group 04.
  • Worn and/or loose driveshaft U-joints/rear axle universal joint ******.
  • Worn driveshaft slip-yoke splines or sticking slip-yoke.
  • Loose engine mounts.
  • Excessive ring and pinion gear backlash.
  • Transmission (backlash).
  • REFER to appropriate section in Group 07.
  • Noise Is Different When Transmission in Drive During Coasting and When in Neutral During Coasting
  • Axle.
  • Transmission.
  • INSPECT transmission. REFER to appropriate section in Group 07.
  • Gear Howl and Whine
  • Ring gear runout.
  • Insufficient bearing preload.
  • Ring and pinion gear backlash.
  • Worn ring and pinion gears.
  • Chuckle Noise
  • Broken gear teeth.
  • Ring and pinion gear clearance.
  • Knock Noise
  • Axle shaft end play.
  • INSPECT and repair axle shafts. REFER to appropriate section in Group 05.
AXLE DIAGNOSIS REAR
  • Vibration and Boom
  • Ring gear and pinion.
  • Rear Axle Noise
  • Differential carrier.
  • Axle shafts.
  • Lubricant.
  • Loud "Clunk" in the Driveshaft When Shifting from Reverse to Forward
  • Driveshaft.
  • Rear axle shaft or carrier.
  • On Turns, the Rear Axle Has a Chattering Noise (Limited Slip or Traction-Lok® Axles Only). Slight Chatter or Groaning Noise on Slow Turns After Extended Highway Driving Is Considered Acceptable and Has No Detrimental Effect on the Limited Slip Axle Functions.
  • Lubricant.
  • Differential.
johnnyreb
West Virginia
Have you looked at the heat shield above the muffler? I don,t know if your year has one,but I noticed my 78 does and it needs replaced.
79' Buckin Bronco
