Looking For Floor Air Actuator/Controller
Pycckue
I know where my main problem lies with my air system, but until I can get it fixed, I'm trying to figure out how to manually change the air to the floor vent. I found the vent/defrost one, but can't seem to find the floor one in that area.
Any insight is appreciated!
If it will not switch to the floor, you probably have a vacuum supply line broken.  The heat doors are vacuum operated.  The safety for a broken line is to put all the air on the wind shield.  You should have a vacuum line going through the passenger side fire wall which is attached via a check valve to the vacuum canister on the passenger side wheel well.
I'll try to find you a diagram and post it later.
Wihill
