Helmmet
When I'm driving my 79 Bronco, my headlights turn off and then back on in +/- 60 sec. Does anyone know what I need to replace/fix?
Thanks for the help, I was hoping not to have to trace all the wires, but it might be the only option left. Sorry for posting this in both forums....I'm new to this computer stuff/forums. Is this the best forum on this site for tech info?your head light switch in the dash may be the culprit, mine would go out randomly or flash a couple times then go out. I would turn off the switch then turn it back on and sometimes they would come back on and sometimes not, it was sketchy, also check for exposed wires that could be grounding out randomly.
That is true, with a heavy duty light harness you will see a significant increase in the brightness of the head lights. The heavy duty harness has larger wire for less resistance and voltage drop. Also, the voltage is supplied directly from the battery rather than the same circuit that supplies voltage for other parts of the truck.To close off......I changed both headlight swithches, cleaned all the grounds and have ordered a heavy headlight harness with relays. I'm told the headlights are going to be 30% brighter. The harness ties into existing wiring and is located after the high/low beam switch.
The harness you ordered,Is it specific for these trucks or is it just some universal kit you tie in?I hate my headlamps dimness,I thought about getting those silverstar headlamps that I keep hearing good things about but they are just about $20 each.Im very good at electrical systems and know how to tie that set up in but wanted to know if it was a complete kit you ordered,and where did you order it from,,,Thanks MikeTo close off......I changed both headlight swithches, cleaned all the grounds and have ordered a heavy headlight harness with relays. I'm told the headlights are going to be 30% brighter. The harness ties into existing wiring and is located after the high/low beam switch.
