lighting issues
1_bad_bronc_85
La Porte Indiana
hi all i am new to this site and need some help with some major lighting issues. head lights work with switch but had to hot wire park, tail and brake lights does anyone have any suggestions? i had no power to my flashers and signals didnt work this is on my 85 full size bronco please help
thank you
When you pull the light switch out one step, do any lights come on at all? Also, I'm moving this post to the 80 - 96 Bronco Tech Support section. How to is for procedural posts.
1_bad_bronc_85
La Porte Indiana
when i first bought the bronc they did come on then when i thought the switch went out i changed it and it worked for awhile but then a few weeks ago nothing but still had headlights so im stuck
Even though the head lights and other lights are on the same switch, they get power from different sources. the head lights are hot directly from the battery via a fusable link, fuse 4 operates the marker lights, parking lights and license lights, that is why I asked if any other lights work. Fuse 8 operates the dome lights, glove compartment, digital clock, and engine compartment lights. Do any of these work?
1_bad_bronc_85
La Porte Indiana
18389[/snapback]
yes they work with the toggle switch. i ended up running an old heavy duty extension cord to run a toggle switch but yes they all work with that
guilhermeknob
