Lifting my 1995 bronco
Beasley
Whats the consensus, should I put a 4 inch suspension lift on my stock bronco and try to squeeze on 35 inch tires or stick with the suggested 33 inch tires or should I just stay stock and go with 33 inch tires? Also if I do go with a lift, what do most bronco people like for their trucks?
Elmo
Forsyth Georgia
My 90 had 3"body lift and 4" rough country suspension lift and fit 35's with room to spare so I don't think you will have any problem even with just the 4" susp. You may see some rubbing in sharp turns or when flexed to the max, that will depend on the backspacing on your wheels .
