lift kit
Bronco in Germany
Nuernberg/Germany
hi guy's ...
:rolleyes: how do i figure out what lift kit i have ?
as you see on the smal picture the bronco has big wheels. they are 32' on 15' rims and
the fenders are cut.
:unsure: can i mesure something to get an idea ?
greatins from southern germany
Bronc76
This maybe a little off but can you read to part no. on rear shocks? (if there is one) The reason I ask is because superlift has different part numbers for stock, 1-2, 3-4, 5-6 lifts. If you know the name of shocks, then you maybe able to check that way. Hope this helps.
"can i measure something to get an idea ?"
---Yes ---
I have the same "rear" flares & wheel/tire size as you. I'm guessing yours is prob. a 3.5" lift.
Measuring fr. the bottom of the flair to the plane equal to the top of the tire....mine's at approx. 6.5 inches.
I have the min. 2.5" lift.
----This is crude measurements, & just an "idea"
There's a way to measure the top/front axle tube to the bottom of the frame., but at present., I don't recall the "stock" distance.
S_bolt19
Colorado
Measure from the top of the axle tube to the bottom of the frame, directly over the axle tube. The front should be 7.5" and the rear should be 7" in stock height. Anything over that is your lift. So if you measure 10" above the rear axle to the frame & 11" in front, you have a 3" lift in the back and a 3.5" in front.
79' Buckin Bronco
