Lift Kit questions
19BigEddie89
Lafayette, LA
So im getting a 6in rough country suspension lift and a 3in body.. The suspension lift doesnt come with extended radius arms and doesnt mention anything about them.. would i need to get some? also it doesnt say anything about an extended drive shaft.. would i need one of those too?? what would be the recomended tire size that i can fit with those lifts??
Thanks.
Krafty
Ontario Canada
your slip rear shaft should be able to do fine with the 6" lift. the lift kit is designed to not need extended radius arms, thats why it includes drop brackets. 6" lift fits tires 35 and 36, plus the 3" body fits 37 and 38. 40 with fender trimming.
19BigEddie89
Lafayette, LA
Thank you.. just finished installing the lift.. didnt go with the 3in body though.. but thanks.
79brnco
