Need to know if I'm missing something. I've got a '96 with the tow package; all stock. Had to replace the rear spring brackets and shackles due to rust. For some reason, the spring eye bushings that Ford says should fit are too small for the front part of the springs (bushings we were given are 1 1/2" in diameter and the eye fits about a 1 3/4"). Ford says all the Broncos and F150s use the same bushings (even though they're different part #s). Anyone else run into this? Thanks in advance.
