L6 300, 4.9L
beefcake282
I was wondering if anybody had a good place to see daigrams or pictures or anything of this engine and or linkages and such. I need to replace/fix parts for things that work like they should and the haynes manual just doesnt show what i need.
I have a real tiny trans, its a 3 speed with overdrive so basically its a 4 speed manual. it almost looks like a car transmission. The engine that I have in it is a 300 L6. The pictures i really need would be of the engine itself with that shows all brackets such as power steering pump which i greatly need and most of all the clutch linkage. The clutch linkage I believe is what I need most besides the powersteering pump brackets.
My bronco has a 3" body lift as well as a 4" suspension lift, but what is dumb is how the guy I bought it from some guy which already had the 3" body lift so the clutch linkages all rigged up badly and I want it to work as well as it should.
If anyone can help I would greatly appreciate it. Thank you.
cjbronco
Jersey Shore
i dont know of a manuel but try www.fordsix.com/forum or try www.ford-truck.com n look at the inline six section. most of those guys know what they are talkin about. good luck n lemme know how you make out
Bradt
Georgia
let me know if you find something. I'm running a 6 too, and it can be a bear finding pics.
Mine's pretty much bone stock, but if you don't find anything in a few days I can probably take some pics of mine for you to compare with.
brad
