okie doggie!
111 was a Pass Code
Self Test - "...A technician that is unfamiliar with the EEC Self-Test can mistakenly believe that continuous Memory codes are not present when they really are. He may run KOER Self-Test and get a pass code (111) and not realize that KOEO Self-Test must be run to receive any Continuous Memory codes. He may run KOEO Self-Test while counting MIL flashes and misinterpret the repeated hard fault pass code (111) to mean that Continuous Memory does not contain any codes. The engine temperature must be greater than 50°F (10°C) to pass the KOEO Self-Test and greater than 180°F (82°C) to pass the KOER Self-Test. To accomplish this, the engine should be at normal operating temperature..." by Ford via miesk5 at home.comcast.net...
so you did do it by warming it up for the KOER..good job!
DTC 538 Insufficient RPM change during dynamic response test. "...This is another code generated when the dynamic response or "goose" test as some refer to it is not performed during the KOER test. The KOER test requires that after a certain length of time the throttle be opened to bring the idle above 2000 rpm for a short period of time. If the dynamic response test is not performed or the rpm's do not peak ABOVE 2000 rpm's this code will be generated. (Computer needs to compare changes in sensor readings at different RPM's to determine system operation and efficiency)..." by miesk5 at Ford Bronco Zone Forums...
A vac leak could cause DTC 332 - Insufficient EGR flow detected
Listen for a hiss; check hose from Valve back to EVR and
DTC 332 & Possible Causes; "...EGR valve sticking closed EGR valve diaphragm leaks EVR solenoid sticking closed Loss of vacuum to or from EVR Open in EVR VPWR or driver circuits Leak or restriction in PFE/DPFE signal hoses.."
DTC 332; "...Continuous Memory DTC 332 indicates the EGR valve did not open with the engine stabilized and the EVR solenoid duty cycle present sometime during vehicle operation. Possible causes: "...Obstructed or cracked hose to EGR valve,Icing, Damaged EGR valve, Damaged EVR solenoid harness..."
Source: by Ford via SigEpBlue (Steve)DTC 332 "...Insufficient EGR flow detected. Atop the EGR valve there is a sensor called the EVP (EGR Valve Position) sensor. It detects movement of the pintle iside the EGR valve. You can apply vacuum to the vacuum barb on the EGR valve and observe through the holes in the casting whether the valve is moving or not. It may just be dirty which requires some careful scrubbing and NO SOLVENTS. Otherwise, if the EGR valve is functioning and moving when vacuum is applied, the EVP sensor is suspect and the electrical connections to it should be checked first. (Computer needs to know the EGR valve position for emissions control)..."
Source: by greystreak92 (Joe B) at fte
Source: by latechsho at Super High Output
Testing; "...There shouldn't be any vacuum at the EGR valve at idle or any time your ass is under the hood fiddling with it, to put it plainly, except for perhaps a very light residual vacuum from the EVR. Check ALL of your vacuum lines FIRST, and the vacuum reservoir for leaks..."
Source: by SigEpBlue
EVR TESTING @
http://www.broncolinks.com/index.php?index=911
If you have detonation; and this is a
VERY LONG SHOT so iggie until all else fails for 322
Detonation and/or Malfunction Indicator Lamp (MIL) Illumination with DTCs 332, P1407, and/or P1408 May Occur Under Normal Driving Conditions TSB 96-23-4 for Various Cars; Just because the vehicle is not listed in the TSB doesn’t mean you may not have a clogging problem; Figures are missing see
Tomco Link Titled, DTC 332, P1407 and P1408 or detonation
Source: by Ford via way2old at fordforum.com
http://fordforum.com/forum/showthread.php?t=7677
Stuck open will act like a vacuum leak and cause a rough idle and stalling
Source: by Larry C at aa1car.com
DTC 332, P1407 and P1408 or detonation; "...We have run into many situations where a code for insufficient flow has been set and the system is functioning correctly. Then it is time to check the EGR passages. There is a Ford Technical Service Bulletin (TSB 96-23-4) that addresses this for some vehicles. This TSB includes: 1992-1995 Crown Victoria 1994-1995 Thunderbird 1991-1995 Town Car 1992-1995 Grand Marquis 1994-1995 Cougar The concerns have to do with intermittent MILs; DTCs 332, P1407 and P1408; or detonation. If exercising the EGR valve does not result in a change in rpm, then the passages may be clogged. There are “U” shaped passages (Fig. 6) under the throttle body adapter that get clogged with carbon. Remove the adapter, clean the passages and reinstall with a new gasket. Just because the vehicle you are working on is not listed in the TSB doesn’t mean you may not have a clogging problem. Make sure you check the passages and be sure they are clean. Just a slight restriction can cause a flow code to be set, and you may still have an rpm drop that can mislead you..."
Source: by tomco-inc.com
I'll post for now
Am looking up your Vacuum Diagram at Ford now; it is same as on top of your radiator; so if you have it trace the Vac line back from EGR Valve; will try to come back soon; but may have to roll until Tes morning
