Kerosene ******
roadkingg
Burgin, KY
Well I did it, and it worked!
The 86 with the 351w with 124k I've been reviving had sat in a yard for 8 years when I bought it in November. I dropped the gas tank,cleaned it out,and changed the oil.
After a dose of Seafoam, I fired it up first of December and have been driving it only around the block to "get to know it a little better".
Last week I finally drove it 15 miles to work and after 10 miles I had ZERO oil pressure according the the OEM gauge. Pulled over and shut it down,waited 5 minutes and restarted- 45 pounds! Went on the last 5 miles and returned home that afternoon with the same issue.
I installed a mechanical gauge and had the same issue so I figured the oil pump screen was getting clogged - or something funky inside,so here's what I did:
Started it up,drove it till it warmed up and drained the oil. Replaced the drain plug and poured in 2 gallons of clean kerosene,fired it up and revved it until it picked up 30 psi on the guage twice.Drained,refilled with Pennzoil High Mileage 10w-40 and drove it 20 miles. Now have 40 psi at 2500 rpm and 20 psi at idle. It worked!!
The motor was really dry and tight after refilling with oil, would barely crank over on the initial restart. All is well, no smoke either!!
Elmo
Forsyth Georgia
the fear involved with doing a clensing that way is the kerosene has minimal **** qualities the fact that it was hard to turn over upon restart is proof of this. it was hard to turn over because the bearings had no **** at all and basically the motor was nearly locked up. I would bet that had you allowed the motor to cool before starting it up with fresh oil it would have not ran again the metal to metal contact of the bearings and crankshaft would have siezed together. I am glad that it worked out for you i just hope it didnt scar the bearings and result in failure down the roda. the last one that i saw done this way used diesel fuel and went from low oil press to a spun rod bearing in just a matter of seconds.
roadkingg
roadkingg
Burgin, KY
Yeah, you're right. I figured I had nothing to lose though. If it runs OK all summer I can rebuild it this Fall. :) /emoticons/[email protected] 2x" width="20" height="20" />
