yo Rog,
I recall this disturbing chain-ofoevents! Sorry!
See if you can find another shop to do a few tests;
Oil Leak and Valve Guide Seal Test
The cylinder leakage detector can be used to test for engine oil leaks and to check the valve seals for leakage.
1.Plug all crankcase openings except the one used for connecting the leakage detector.
2. CAUTION: Use extreme caution when pressurizing crankcase. Applying air pressure above specified pressure risks damage to seals, gaskets and core plugs. Under no circumstances should pressure be allowed to exceed 27 kPa (4 psi).
Connect the detector to a crankcase opening (oil level indicator tube (6754) is convenient) and adjust the air pressure to approximately 20 kPa (3 psi).
3.Using a solution of liquid soap and water, brush the solution along the gasket sealing surfaces and bearing seals. Look for bubbles or foam.
4.Remove the spark plugs (12405) and rotate the engine (6007) slowly with a wrench. Check for large amounts of air escaping into the cylinders as each intake and exhaust valve opens.
The spark plugs on the leaking cylinders will probably show deposits of burned oil.
Compression Test
1.Make sure oil in crankcase is of the correct viscosity and at proper level and battery (10655) is properly charged. Operate vehicle until engine (6007) is at normal operating temperature. Key off, then remove all spark plugs (12405)
2.Set throttle plates in wide-open position.
3.Install a compression gauge such as Rotunda Compression Tester 164-R0250 or equivalent in No. 1 cylinder spark plug opening.
4.Install an auxiliary starter switch in starting circuit. With key off, and using auxiliary starter switch, crank engine at least five compression strokes and record highest reading. Note the approximate number of compression strokes required to obtain the highest reading.
5.Repeat test on each cylinder, cranking the engine approximately the same number of compression strokes.
READ MORE @
http://www.diesel-dave.com/vehic/manual/stj/stj30010.htm
Pick other tests at
http://www.diesel-dave.com/vehic/manual/stj/stjs300l.htm
Intake Manifold Vacuum Test
Vacuum Gauge Readings, Interpretation
http://www.diesel-dave.com/vehic/manual/stj/stj30013.htm
excerpt;
Bring the engine (6007) to normal operating temperature. Connect Rotunda Vacuum/Pressure Tester 164-R0253 or equivalent to the intake manifold (9424). Run the engine at the specified idle speed.
The vacuum gauge should read between -51 and -74 kPa (15 and 22 in-Hg) depending upon the engine condition and the altitude at which the test is performed. SUBTRACT 5.5 kPa FOR EVERY 500 METERS ABOVE SEA LEVEL. SUBTRACT ONE INCH FROM THE SPECIFIED READING FOR EVERY 1,000 FEET OF ELEVATION ABOVE SEA LEVEL.
The reading should be quite steady. It may be necessary to adjust the gauge damper control (where used) if the needle is fluttering rapidly. Adjust damper until needle moves easily without excessive flutter.
A careful study of the vacuum gauge reading while the engine is idling will help pinpoint trouble areas. Always conduct other appropriate tests before arriving at a final diagnostic decision. Remember that vacuum gauge readings must be interpreted with care.
Most vacuum gauges have a "normal" band indicated on the gauge face.
Take the test and see what it shows; could be to confirm your suspicion; "7.POOR VALVE SEATING: A small but regular downscale flicking can mean one or more valves are not seating."
etc.
GL!
