I have a 95 Bronco that will turn over, but won't start. I don't hear the pump when I turn the key on now. Is there a way to replace the pump without dropping the tank? Any help would be appreciated!!! Thanks
28456[/snapback]
soundslike a bad pump same thing happened on my mustangOk, Sunday, I worked on my truck. There was 30 gallons of gas in the tank, so I decided to try carefully cutting a hole in the bed above the tank. I drilled holes at the corners and then used the shortest jigsaw blade I could find(18 tpi so no sparks were made. Worked like a dream. But then I could not budge the pump retaining ring. Decided to give up and take to a shop, but for some reason tried to start it once more. Low and behold, the pump whirred to life when I turned the key and started right up. Worked great until today. I took my hole patch up and tapped on the top of the pump with a rubber mallet and tried starting. Alive again!!!. But have had to do that several times now today. Is this a bad pump, or an electrical problem....Please help!?!?!?!?!
28656[/snapback]
28456[/snapback]
