I have been back on the road after replacing numerous parts that I thought would have an adverse effect on passing an auto inspection. I recently completed a complete tune up wires, plugs, distributor , etc. I had my catalytic converter replaced, and 02 sensor. I even changed my air filter and fuel filter. I went to the inspection place and I am running too rich!!I failed HC 235 over 155 (155 being the standard) I failed CO 7.69 over 1.91 being the standard. My levels are way too high. I checcked my code reader and it is telling me codes 23,31,53,63. (23) = Throttle position sensor out of range, (31) = EVAP control system below minimum voltage( What the heck is an EVAP?) Does this have anything to do w/ EGR or Emissions vac controls?????, (53) = Fuel injection pump lever sensor input greater than self test, and (63) = Throtle position circuit below minimum voltage. I knew I would have to probably change the TPS because I had to change the TP sensor in old my 89 Bronco. Does anyone have any suggestions or insight?
Help get an old 86 eddie bauer 5.0 on the road [-o<
