ignition wiring harness
SleeperStyle
Media, PA
ok so i am getting ready to do a keyless entry and a remote stater. the only problem is that the wiring diagrams that i have for an '88 don't seem to match up with that in the truck. the ignitions wires and harness seem to be different colors then what they have listed. does anyone know what wires are what under there? and if it helps... '88 XLT w/302 thanks
Not sure which wires you are interested in, but here are a couple. The wire from the Start position to the start relay is red with a light blue stripe, also goes to the TFI module. The run wire is red with light green stripe. the run line to the fuel injector cooling fan is gray with yellow stripe. the line to the EEC power relay is white with light blue stripe it also goes to the (+) post on the coil and TFI module.
