If you can figure it out, you're smarter than I
wwatsonh
88, 5.0, AOD
Okay, here's my problem and a not so brief description of what I've done to diagnose/correct it thus far. And yes, I've searched, and I've been to the fordfuelinjection website several times.
I've owned this truck for about 2 years, and the check engine light has always been on (p.o. removed the bulb, I put it back). Code 31 has always been the biggie. I initially changed the EGR valve (it was stuck), then the EVP (the resistance was way jacked up) but that didn't fix it. I then realized that most of my vacuum and/or emission lines were broken, missing, or otherwise inop. So I left it for awhile.
I finally got off my butt, went to the boneyard, and got a new vacuum harness for it (all the hard lines bundled as from the factory). The truck now runs much better. I erased the codes, and started over. Did a KOEO test with my scanner, got a 31 again. :((
So....I checked the EGR valve (it moves with vaccum applied from a pump).
I checked the resistance reading on the EVP (4400 ohms closed to 330 ohms with 10in vacuum). According to my books, this is in range.
I next tested the voltage at the EVP harness connector (4.6 volts) again, in range.
Then, I checked the resistance between the harness connector at EVP signal to socket 27 on the connector to the EEC PCM (0 ohms) once again, exactly what it should be.
I then checked the resistance between the harness connector at EVP signal to ground. I got that the circuit was open. Good, no short to ground.
Next, I checked the harness connector for stray voltage at EVP signal (none found). Good, no short to power.
Now I'm stumped.
I want to clear this KOEO code, so that I can proceed with whatever else may turn up when I do the KOER test. I'm trying to be methodical, sytematic, and not throw parts at it until I know what's wrong. ANY ideas/suggestions would be greatly appreciated.
SOMEBODY SAVE ME!!! [-o<
Will
bluesman17
Spam Terminator
South Bend, Indiana
If it aint broke dont fix it. I no longer have a check engine light and am much happier without it as the trucks running great for the time being.
brian_n_texas
Melissa, TX
Will,
I think you are approaching this problem correctly, I wish I had a nickel for every dollar I have spent throwing money at problems by replacing non-faulty parts, I would be a proverbial millionaire.
Do you have a shop manual? Not a Haynes or Chilton, I mean a bona fide mechanics shop manual. If you don't have one, I would suggest that you hunt one down, start with eBay. One of these could definitely help in further diagnostics.
If you do have a shop manual, then - I am guessing here - it could be an intermittent problem in the electronics. First thing I would do is unplug all electrical connections and re-seat them after applying some bulb grease to make sure ALL electrical connections are good (I have a boat, believe me this can often make a difference). After that I would chase down what has to happen to diagnose the electronics, 7 year old chips somewhere could be an issue.
Let us know how it goes, good luck!!
Brian
Tevbuddy
Is it sluggish at low speeds,like starting out and going slow through ...say a school zone.If so unplug the EGR controls,the vacuum ones.They also have an electrical connection going to them.Then drive it .If it gets better then replace them as a pair.THEY ARE NOT CHEAP......DEALER ONLY ITEM.It is common from late 86-89 or so.
eholt80
