1966 roadster
I have a all ORIGINAL 1966 u13. 170cid with the original carb. I was driving, and around 3500 rps the carb hesitated. it only did it three or four times. i new that it was a warning sign so i went straight home. I shut off the bronco let it cool so i could work on it. when I started it back up, it started fine but as soon as i give it any gas it chokes and sputters. I have replaced with NEW.
FUEL PUMP
FUEL FILTER
COIL
PLUGS------- ALL 6 gap set at .034
WIRES--------ALL 6
CONDENSER
ROTOR
POINTS set at .025
DISTRIBUTOR CAP
REBUILT THE CARB
AIR FILTER
Even with all these items replaced it STILL DOSE THE EXACT SAME THING!!!!!!!! Its driving me crazy.
I can start the bronco, let it idle till it wets warm 180 degrees. and still no change. I have removed the fuel cap. NO CHANGE. I have tried to set the gap on the points from .015 (ran like crap) all the way up to .032 ( ran like crap}. AT IDLE I HAVE ADJUSTED THE AIR/FUEL MIXTURE AND HAVE IT WHERE THE ENGINE RUNS SMOOTH. I have tried to adjust the air/fuel mixture while ATTEMPTING to give it throttle but still wont run past idle
FUEL PUMP
FUEL FILTER
COIL
WIRES--------ALL 6
CONDENSER
ROTOR
POINTS set at .025
DISTRIBUTOR CAP
REBUILT THE CARB
AIR FILTER
