idle problems
blkwlf
help idle problems
95 5.8, efi, have replaced the TPS, MAP, Cap, Plugs, Rotor, coil, EGR and control valve, Vacuum solenoid, IAC valve. i have checked for codes, either KOEO and KOER, but nothing. the problems: the idle fluctuates about 200-300 rpm's up about 2-3 times a minute. runs fine any help would be appreciated.
19Bronco93
Camden, DE
your answer.......
---DIRTY FUEL INJECTORS---
the 5.0/5.8's efi system's fuel rails were not set up the best. the way they are mounted does not let them drain properly, collecting rust and a lot of other fun, surprising items that will build up over time. The best way to approach this problem-
-try a cleaner for sale at a auto parts store like lucas, but i prefer seafoam myself.
-if that does not work, the ford dealer sells a fuel injector cleaner, while on the pricey side, like 30 dollars a can, works well.
-if that fails to work, check the timing, fuel pressure, etc.
-if everything checks out, take it to get the fuel system serviced like i did with my 95 f150 with the same problem, have a mechanic put a new fuel filter on, clean out the injector rails and a good tune up never hurts. while on the pricey side, it will fix your problem, almost guaranteed.
BroncoJoe19
hmmm... my first thought.
No codes... surging idle.
Look for a vacuum leak.
Haynes also mentions a plugged PCV valve as a possibility.
joe
Chapin1736
