I've been experiencing some issues with my idle speed while my engine is hot. It runs fine when cold start, idles great. However once I have been running engine for about 20+ minutes, the idle speed drops to about 600-700rpm's and sounds like the engine is struggling to stay running.
If I drive anywhere and shut the engine off, then try to start while engine is hot it will usually fire up but once I shift into Drive or Reverse the engine starts choking and will eventually stall. I'm not sure why it is only happening when engine has been running for awhile, any suggestions on where to start? I was thinking possibly electric choke is going bad? or vacuum leak somewhere? Just not sure.
Thanks for any help
Thanks for any help
