I Keep Burning Ignition Modules
iaff1386
I have a 77' and I'm experiencing an electrical problem. I keep burning up ignition modules. I have replaced the battery, battery cables, ignition relay, voltage regulator, alternator, plugs, plug wires, rotar, cap, coil and ignition module. The beast fires up great and runs for a few minutes then BANG, huge backfire and I have blown up another ignition module. What am I missing? Where do I need to go?
Broncoholics
Broncoholics
Washington State
What size altinator and voltage regulator did you install? Is it close to stock?
I'm not sure but I thought I heard if you have too many wires connected to the back of the key then you will creat too much ampers and usually blow fuses but perhaps it back feeding into the ignition moduel? Take a look under the dash and see how many are connected to it.
79' Buckin Bronco
