Hub Issue
skidordie6531
My auto hubs destroyed themselves and when i went to replace the wheel bearing while i had it in peices the outer nut came off but it evidently messed up the threads now the inner nut will not come off to allow the removal of the bearings so there lays my problem which parts would i have to order to aquire from a junk yard in order to fix it as my wife bought this while i was overseas and well it has issuies and i just want to fix it the right way the first time instead of contuining the nickle and dime fixs.
Thanks
Jon
If the threads on the SPINDLE are "boogered up", then that's the part you'll need to get used or new. IF the bearings are seized on the axleshaft itself, then you'll need an OUTER STUB shaft from the u-joint. JSM84
Motormouth2025
