How to remove / replace
michibronc
Flint, MI
I've searched the how to forum - no luck. I need to remove the weatherstripping around the doors to do my herculiner project. Would like to reuse it if possible - it's in good shape on my '96. How do you remove and reinstall?
You need to remove any trim pieces that over lap it and it should just pull off the ridge it is mounted on. Reinstall by pressing it back on.
crazyhorse85
clarksville,tenn
YEP,SEABRONC IS RIGHT REPLACED BOTH WEATHERSTRIPS ON MY 85,ONE I DID WITH THE TRIM INPLACE AND WAS A PAIN IN THE #SS...IT DOESN'T TAKE BUT A COUPLE EXTRA MINUTES TO TAKE THE TRIM PIECES OFF OR JUST BACK THE SCREWS ALMOST OUT SO YOU CAN MOVE THEM BACK ALITTLE AND IT WORKS ALOT BETTER....THEY JUST PULL RIGHT OFF AND SLIDE RIGHT BACK ON....
Chapin1736
