winks
In order to get further along with my lift I have to get this part off on each beam to get to my trailing arms. This post threads into a nut welded onto the beam (cannot get to) and the springs and sway bars thread onto the top portion. The welded nut inside the beamhas a crapload of dirt and rust on it, and I can't get to it. I have soaked the part in PB Blaster (penetrant) and heated up the nut and surrounding area with a torch, but nothing has worked yet. I do not know of a socket big enough that can fit this piece, it would have to be a 1-1/8" socket that's 3-4" deep. The wrench that I tried using (with a 3' piece of conduit on the end) only strips the bolt, and the largest pipe wrench I have doesn't allow me enough torque to move the bolt, nor has the ability to fit the conduit.
Does anyone know where I can pick up a deep socket deep enough for this application?
Stuck post
My deep socket next to stuck post
*Note: socket only clears up to the chamfer, roughly 2"
Welded on nut that I cannot get to
Alternatives:
1: Cut the bolt to a point where I can get my socket on there and torque it off with the conduit. Then go to Ford and hope I can get a replacement bolt.
Pros: part comes off, everything goes back into place.
Cons: may not be too easy to find the part and I'll have to search around.
2: Cut the bolt to a point where I can get my socket on there and torque it off with the conduit. Leave the sway bar off because it won't fit on the cut up stud and put the rest of it back together.
Pros: part comes off, more articulation without the sway bar
Cons: no sway bar makes driving a full-size truck at road speeds a bit more difficult.
3: Use somebody else's idea and go from there. Hopefully somebody will have a better idea or a place to get the deep socket that I need.
Stuck post
Alternatives:
