highway driveability
bigbadbronco
colorado
I have a '73 EB with a 302 and a 3 speed automatic. The setup was perfect when i lived in the mountains and never drove above 60 mph. However i recently moved to denver and need to go faster. What is the easiest (and cheapest) way to swap in a four speed to hopefully keep me from burning up my hot 302 :)>-
bigbadbronco
colorado
Have you considered changing the differential gearing?
I forgot to mention that the transmission is burnt and needs to be replaced....So I guess my question is: Is it possible to replace a 3-Speed Automatic Transmission with a 4-Speed,,,,and is it a good idea?
STLKIKN
Calgary Alberta
Anything is possible...
Check out the Advance Adapters website and online catalog.
There you will find the info (and parts) necessary to swap either an A4OD or even a GM 700R4 into your truck.
S_bolt19
Colorado
I would just do the WH NV4500 or ZF-5 speed swap if you are looking for highway driveability. Yeah, both are expensive, but you don't have to change gears in the axles. The NV & ZF are 5 speeds whereas the NP435 or the T-18 are 4 speeds and those are truck trannys. If you ever get a chance to come to Colo. Springs, PM me and I will take you over to a friend's junkyard full of EBs and he might even have a 4 or 5 speed tranny around. Any way you look at it, it is going to run you in the neighborhood of about $6-800 to either get your tranny rebuilt or as high as the WH NV swap at $2500. Just depends on what you want to spend.
bigbadbronco
colorado
thanks alot for your advice. im in the springs relatively often and would love to see your friends yard. im not sure i need the five speed, but if its an automatic ill consider it.
S_bolt19
Colorado
Are you looking for a 4 or 5 speed auto or a manual? I might have misunderstood you, thinking that you wanted a manual. All those that I listed (NV, ZF, Np & T-18) are all manual trannys. If you want an auto, then you need to find a C4 or C6 AOD.
bigbadbronco
colorado
four speed auto, i dont want to mess with the linkage or have to cut in a clutch,
STLKIKN
Calgary Alberta
Four speed auto is gonna be almost as much work as putting in a four or five speed man tranny.
Almost any swap you do is going to change your front and rear d shaft lengths, your crossmember placement in the truck, and in some cases even not being able to use the factory crossmember.
The one trans that "fits like a glove" so to speak would be the NV 3550
which is a 5 speed manual trans.
If you don't want to make any other mods to your truck, your best bet may be to have the C-4 rebuilt.
bigbadbronco
colorado
i have a baker trans on my bike, which i recently had rebuilt as a six speed. do they have a similar system for turning the c4 into a four speed
bigbadbronco
colorado
I found a four speed auto from an '84 full size bronco, what model is it and does anyone know if advanced adapters makes a kit for the swap into my '73
northernleitz
Northwest AK
That's an AOD and yes they do. Basically your only choices for putting a four-speed auto into your early Bronco are the AOD and the AODE/4R70W as I understand it. The E4OD/4R100 is too big and adapters aren't available. Now, my concern is how to adapt the D20 J-shifter to the AOD/AODE adapter. All I can get out of Advance Adapters is that it requires ingenuity.
northernleitz
Northwest AK
Check www.tomsbroncoparts.com. They have good prices for the Advance Adapters adapter you will need. They also offer a crossmember, though your original can be modified to work (you need to make room for the adapter).
AdamDude04
July 2006..old thread lol I'm sure he's got it figured out by now!
Good info though..knew idea you could swap those years around
79' Buckin Bronco
