Highlighted posts from Tuesday, Nov. 09, 2021
  • Thread starter Top stories on BroncoZone.com
  • Start date
T
Guest
Click here to view on the web
Highlighted posts
November 04, 2021 * 7 posts * 344 views
Atanasd84 said: put a new 5.0l long block in a 88 bronco. I'm having hard time starting engine. I have set initial timing to 10BTDC BY THE BOOK. New distributor. Wires. Plug . Wires are going ... Read more >>
November 07, 2021 * 9 posts * 193 views
96broncorojo said: Getting cold up here in Fairbanks and the drivetrain is starting to get louder and causing vibrations. It's handling higher gears well but it's taking a lot of work to get uphill. ... Read more >>
November 05, 2021 * 4 posts * 394 views
darknite said: hi everyone on my second bronco and i am conflicted. i am on my second bronco and its a red 95 5.8 xlt sport with 139xxx miles on the clock. she runs and has a fair share of rust(more ... Read more >>
November 05, 2021 * 2 posts * 217 views
SoFloBronco said: Just bought new rainx wiper blades for my recently acquired bronco. Had our first rains since I bought it and the blades on both sides are missing an area in the middle of the ... Read more >>
November 03, 2021 * 2 posts * 281 views
jimbronco91 said: I have checked previous posts but I didn't find anything on actual Torque Specs for Tie Rod Ends for 1991 Ford Bronco. I am trying to finish while there is a break in cold weather. Read more >>
November 03, 2021 * 2 posts * 223 views
bhbronco said: I have a 1972 bronco I am looking for someone to do a classic restoration. I am located in Ohio but willing to ship out of state. I can not seam to find anyone in the Cleveland ... Read more >>
November 05, 2021 * 39 posts * 1,294 views
johnnyreb said: Well I went back to the start of your article and saw .Where your ac unit is a dealer installed unit. I kept looking and nothing came back looking like you. Then I re-read the ... Read more >>
November 02, 2021 * 3 posts * 280 views
miesk5 said: Yo DJ, Call local Ford dealer parts department and ask for ***** N55929-S58 Do same for another parts. Following from 1996 Bronco F Series Workshop Manual @ [link] Section 01-05: ... Read more >>
November 06, 2021 * 1 post * 97 views
miesk5 said: Sell or Buy your Bronco or Ford Truck at [link] Read more >>
November 05, 2021 * 11 posts * 684 views
miesk5 said: Yo Jim, If EGR valve is stuck open, it will essentially cause a vacuum leak, leading to inefficient combustion, rough idling, hesitation & sometimes, stalling. jowens1126 has an ... Read more >>
Continue reading...
Similar threads
T
Replies
Views
1K
T
T
Replies
Views
1K
T
T
Replies
Views
2K
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
79' Buckin Bronco
