Hey Any One No Were I Can Get The Parts To My Top?
Dark_spart
hey guys i have a 95 ford bronce with a soft top im trying to take it off and put on the hard top problem is when takin the hard top off the bolts and clips were ruined and ford has discontinued the parts <_< so if any one knows were i can find them please tell me thanxs
brian_n_texas
Melissa, TX
Yeah, I had to cut half of the bolts holding down my top to get it off, they were rusted up...
I would take one of the bolts and a clip to a NAPA auto parts store and see if they can match up something close enough to work.
BNT
murph
North Carolina
I need to replace the nut plates on the attach bolts. Do they carry them at advance too?
murph
North Carolina
nut plates? where are those? they may have them, ive  never looked.
25821[/snapback]
They are what the bolts ***** into. They are inside the holes. I work on F-15's and that is what we call them.
muddog
Indianapolis, IN
[i had to cut the rusted bolts off of my 93. if you remove the panels on the inside there and feel under neith youll see that it is flat and smooth all the way down the side. i bought a steel strip about 2 1/2 TO 3'' wide and drilled all new holes and bolted (or weld) the steel strip under there. then i got hardend steel nuts washers and bolts and use those to hold her down. they are a lot easier to take apart or put back together than those stupid torx screws.
joekot
Northern Va
hey you're taking off your soft top... does that by any chance mean you are trying to get rid of it?? if you are.. my email is jkot14@***.net and i'm looking to buy a soft top for my '89 if you are looking to sell..
http://broncograveyard.com/bronco/i-38251_..._clip_80-91.htm
^^^ $39.00 on bronco graveyard for a complete set of 13 bolts and clips. ...i'm only missing two and my top seems to stay on fine but i may have to throw down 40 bucks to be on the safe side... plus hopefully new ones would make it less of a bitch to ***** in all of them u know,,
ocalabronco
ocala, Fl
where are you located? i have all of the fasternes and trim from my hardtop, which you can also have if you like
TrishC
