ChappDogg
Need some help, both the rear antilock brake light yellow and brake light red stay on.
I have had a bad vibration problem after I did a 4" lift, so I thought I put the rear springs with shimes on wrong. So I turn the shims around and took it for a ride :-" WRONG thing to do, after awhile I stop and put the E-Brake on, after I released the E-brake, the lights came on and the rear brakes locked up. Got it home and flipped the shimes back around to what I had the first time and all was good for alittle while, than the light came back on. No brake issues, so I was wondering what I should check first? I did some reading but got no idea where to start? The Vibration I figured is either the angle of driveshaft or bad joints. It's bad at 25 to 35 MPH. Thanks for any and all help.
ChappDogg
ChappDogg
