HELP-Discontinued OEM fuel line needed
Gymrat
I have a 1996 Ford Bronco XLT, 5.8L V8 that has a fuel leak in the line that connects to the fuel filter and runs back to the top of the fuel tank into the fuel pump. The part number as per the service manager at the Ford Dealer in Lawrence, Kansas is F6TZ9S278J. They say this part is no longer in service, obsolete, never again and we can't help you buddy. So, I am looking for this part. I've checked several parts places online and come up empty handed. If anyone can help I'd appreciate it a lot.
try, http://peerlessauto.net/
And let them know we refer them to other owners a lot.
If they don't have any, ask them for a poss source; some yards out there may pull the hubs and store em; bec. they know the value... whereas around here, PCMs are pulled and left out in the swamps
How about Steel Fuel Repair Lines? Am surprised that the service manager didn't suggest this; but some doesn't want to get into any repirs outside the EVTM/Service Manuals; our former, now closed dealer service manager would repair anything that had a Ford emblem on it.
General Motors / Ford / Chrysler repairs, rusted and leaking fuel lines
OEM style flare with viton O-ring (Brown)
by FMSI
Give em a call because they say; "Although we have a physical library of over 14,000 parts, we can reproduce any line in OEM or stainless steel working from your original. If we do not have your application, we can make it custom for you. When we receive your original, we will call you with a quote. Once the quote is accepted, the new part(s) will ship within a few days. Prices for custom duplication are based off similar lines in our catalog with a slight up charge."
or,
Gann manufactures and distibutes a complete line of fittings, including our glass reinforced nylon line, as well as brass, zinc, steel and stainless steel.
I checked;
Inline Tube - Bronco/Ford truck pre-formed brake line sets, hoses, fittings, & rubber fuel hoses, etc. NONE Give em a call
FHS-301
FHS-303 Rubber Fuel Hose Sets $4.50
3/8" (2') Hose with 4 correct Color Clips
Used for both ends of Main Fuel Line
5/16" (2') Hose with 4 correct Color Clips
1/4" (2') Hose with 4 correct Color Clips
Classic Tube - pre-bent & custom stainless & OEM brake & fuel, trans & vacuum lines NONE
MTS - Bronco/Ford truck polyethylene fuel tanks; sending units for FMSU-33E 33-Gallon tank 78-84; FMSU-3 F series 19 Gallon side tank; FMSU-4B F series 19 Gallon rear tank, Fuel pump not included 87-89; FMSU-5/5B F series 19 Gallon side tank, Fuel pump not included 90-91 & 5B 87-89; FMSU-33E Bronco 33-Gallon tank 78-84; FMSU-2 F series rear mounted tanks. Will also fit 73-79 & 80-84; lock rings FMLR-1 Ford 2" hole 66-89; FMLR-2 Ford 3 5/8" hole 85-96; straps
NONE
Similar threads
T
Replies
Views
1K
Top stories on BroncoZone.com
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
T
Replies
Views
837
T
Ford644
