Heavy Duty Spring Swap
Rons beast
Measure the width of the front and rear spring eyes, and the length between the front to rear, of the 250 springs. If they match the 150, you have no problems with fitment. If the 250 springs raise the rear more than an inch or so you may need to compensate for pinion angle with a wedge spacer to keep the driveshaft aligned.
Ford644
