headers heating up
rogmit
well i fixed the ignition problem with the distributor being rebuilt, then my fuel pump went out, so i got that replaced and my truck starts now but the headers are turning cherry red after it runs a few minutes, also i removed the shrader valve on the fuel injection fuel rail and i put in a fuel guage where that valve was, is that causing a fuel problem or does it sound like a catalytic converter problem. what's does any body think the problem is?
Without more info on the truck & engine it's hard to say for sure but it sounds like a mixture problem. If it's turning the headers cherry red then you're running *way* rich. The excess fuel is continuing to burn as it leaves the head thru the exhaust ports and it's superheating the headers and that's why they're turning red. Might be a fuel pressure problem (a pinhole leak in the regulator) or it might be a processor problem. Might be something like a bad O2 sensor telling the processor that the engine is running lean so it's trying to compensate by pumping in more fuel. There are a number of things that can *cause* the problem but the root of it is too much fuel. Did this start immediately after you replaced the fuel pump ? You put a gauge on it but what was the reading ? Just HOW much fuel pressure are you running ? A blown regulator will let too much fuel in. Is the truck throwing any codes ? Is the Ck Engine light on & if so what codes is it giving you ? What do the sparkplugs look like ? are they black ? Does the exhaust smell like fuel ? I'm going to assume that you've *double* checked the timing to be sure it's correct. How old are the injectors ? I've seen a bad injector O-ring spew a lot of additional fuel into the engine cause a pig-rich condition. Do *both* headers get just as hot ? Is it one side more than the other and can you maybe *see* if one tube in particular is getting hotter than the rest ? Do you have black smoke in the exhaust ? The processor could also be going into a cold-start mosde & giving it a lot of choke if it's getting bad info from the IAT, inlet air temp sensor or ECT, engine coolant temp sensor. While a blocked converter is *possible* that hasn't been a real problem for an awful long time, the late 70's/early 80's converters had a tendency to fall-apart internally and block the exhaust or guys who still had access to leaded fuel would use that and destroy them internally but I haven't seen or heard of a bad converter in quite some time, that's not to say it doesn't still happen occasionally but it wouldn't be high up on the list of suspects.
bigtrux
Murrieta,CA
DITTO with bronco bill definatly too much fuel. I had this prolem with another vehicle it was a combo of 3 things a bad o2 sensor timing was off as well as the idle... becuz whoever had it before me just didn't know what they were doing and had it all messed up . A clogged cat is always a poss . but i would check the timing and idle. also the o2 sensor... Good Luck Trux
