Header Blue's
flame351
:unsure: some one help me! my problem is i have a 84" bronco w/351w ****** headers and pass. side hang's low to go under the 't' case. Is their any one using headers that hug the body and if so what kind ? thank's flame351
BigNasty
SquirrelBait
NC
My 82 shouldn't be too different from yours with the exception of a body lift (4" here) possibly.
On mine, starting from the header ****** to the muffler.
You can see the extreme angle that had to be welded onto the ******. This was a bend, cut in half. Inbetween the green lines, you can see the passenger side exhaust.
You can see how the pipe goes above the transfer case, yet still has ample room for the floor pan.
Same pipe, different angle.
And to the muffler.
Maybe this will give you some ideas about how to route the exhaust.
As you can see, my exhaust is purely functional frankensteined pipes.
If you are not concerned with being smog legal :-& , BigN has the best solution, 4" lift and over the top. I don't see cataletic converters on these :ph34r: /emoticons/[email protected] 2x" width="20" height="20" /> . If you happen to live where that kind of stuff is checked for :ph34r: /emoticons/[email protected] 2x" width="20" height="20" /> then you have to come up with a way to fit CATs into the picture. :unsure:
Shadow_D
Schenectady, NY
Looks great except for the exhaust leak at the muffler in the bottom picture. b-( In case you don't know what I am looking at, it is the black stuff that looks like it is coming forward.
