Hazard lights
pcrox200
So I just bought a 1993 Bronco XLT, and the turn signals, parking lights, brake lights, headlights all work, but the hazard lights seem not to? I was thinking the switch, but I just wanted to make sure it isn't something easier and won't cost me as much as buying a new one. I've already checked the fuses and replaced all the burnt out ones, so that shouldn't be a problem. If anyone can help it would be greatly appreciated.
Sounds like a fuseable link. Most of the fuseable links are at the battery side of the start relay.
Good luck :)>-
yo;
try this too
Hazard, Turn, High & Low Headlight Dimmer, Flash-to-Pass, Multi-Function Switch (MFS) & Brake Light Testing & Wiring Diagram in 92-96;
Source: by Steve83 (Steve, That dirty old truck) ath ttp://www.supermotors.net/registry/media/225114_1
it's an internal test of the MFS;
Miesk5 NOTE; the MFS testing is done with connectors disconnected;
Brake Light & Turn, High & Low Headlight Dimmer, Flash-to-Pass & Hazard CKTs are a Feed-Through Circuit in Multi-Function Switch (MFS)
If it is da MFS;
Multi-Function Switch (MFS) Failure Causes; "...Mechanical components wear out or electrical connections are faulty; If the switch assembly is not operating properly, turn signals, hazard warning lamps, windshield wipers/washers and the headlamp beam selection may not operate properly. Related Components to Check; The switch itself, the electrical connections to the switch and the connections to each of the affected components (items such as turn signals, wipers, etc.)..." miesk5 Note; enter applicable info for year, etc.
Source: by motorcraft.com
Multi-Function Switch (MFS) Cleaning & Internal pics in a 2001 Explorer; Miesk5 NOTE, as Steve wrote it should be electrically & functionally identical to our years; "...Wipe with a rag, hit with contact cleaner and an old toothbrush to clean. Regrease with dielectric grease. Save ~$80 for a new switch that will only last ~4 years..."
Source: by Electrohacker at http://sites.google.com/site/mfs01explorer/
Multi-Function Switch (MFS) Replacement in a 96
Source: by boss (bossind, Steve) at http://www.4x4preservation.com/forums/showthread.php?t=387
AdamDude04
No real answer from me.. but a fun bypass :) /emoticons/[email protected] 2x" width="20" height="20" />
I still have to install mine
$200 for everything - Whelen strobe kit 90watt system
Elmo
Forsyth Georgia
I would recheck the fuses again. A fuse blows for a reason not just because. So if you had blown fuses then there is problem(s) in those systems. Recheck fuses and pull the bulbs and check for voltage to the sockets with the hazzard lights on. A shorted bulb socket will blow a fuse.
