well.. it was a little more intense than just the one bolt that has worked loose in the past...used the red loc-tite on it and it was tight, both coming out and going back in
/emoticons/
[email protected] 2x" width="20" height="20" />
The bolt was tight, so I pulled the starter and got a replacement (warranty
/emoticons/
[email protected] 2x" width="20" height="20" /> ) due to it not having the power to properly engage and spin the engine like it should.
It had enough power to almost engage the flywheel and gnash pretty loudly. Good thing is that with it not qite engaging, there was no damage to the flywheels teeth, just the tip of the starters gear chewed up.
So.. after taking 5 minutes to pull it out.. and 2 hours fighting it to go back in and bolt up..... fun times... I came up with curse words noone else had ever heard, so I'm not sure if they are real or just the part of my brain that went fetal just babbling incoherently... it started like a champ on the first try.. I think the excitement made me *** a little too, not positive, could be an age thing or the pain of the oil that dripped in my eye
/emoticons/
