going crazy (brakes)
DonLawson84
When i got this bronco, the brakes were soft.  ran alot of new brake lines, replaced hoses and brakes still soft.  replaced rear ***** cylinders and master cylinder.  Brakes are still soft.  Bled many times, all new brake fluid flushed to each wheel.
Everything is functioning as should, brake light went out after master cylinder replacement but if i mash the brakes while rolling, its not a abrupt stop like it should be.
Rons beast
Hey Don,
Have you adjusted the rear brakes properly?  If out of adjustment, the pedal will feel softer and have more travel befor becoming firm as it should.
Good Luck
D
DonLawson84
I will have to check the. After driving it a little more, doesn't seem as bad (was just driving up and down street)
D
DonLawson84
did the adjustment on sunday, definatly got about 6-7 clicks on both sides.  brakes did not get any better but i think its more being paranoid, had a buddy drive and he said felt good.  thanks for the input
guilhermeknob
