Gas tank vent tube
AdamDude04
Okay so I'm tired of trying to pump gas in. In my other vehicles, takes a meer 2 minutes to fill a 37 gallon tank if that. The bronco..uhh 30 minutes?
Anyway, I was thinking of adding a vent tube.. anyone do this yet?
I was thinking of drilling a hole near the fill tube..running that tube through a fuel filter (clear one I have) and tap a hole where the gas cap is..this way I can place a cork in the tube when not filling up. Will this help letting excess fumes come out, or will I need a whole new fill tube? I want to solve this, soon.
Adam, we went through this at least once before here; how about going back and read any replies to your Questions from now on? You can bookmark the tposts or save it as a Favorite and then go back preiodically to review it for replies.
http://broncozone.com/topic/19811-slow-to-fuel/'>http://broncozone.com/topic/19811-slow-to-fuel/
You have one already in it; it may be kinked, fouled or whatever;
Vent & Fill Tube pics in pre 87 & 87 & up; "...Early trucks use a small corrugated plastic vent tube tucked into the top of the steel filler neck , but it often kinks & blocks fuel from entering the tank easily. Later trucks use a heavy plastic filler hose inside the steel vent neck, which allows MUCH easier filling.The necks are interchangeable, so it's a good upgrade for an old truck, especially if filling is becoming a problem. It also allows the use of a more modern gas cap..."
Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net Vent & Fill Tube pics in pre 87 & 87 & up; "...Early trucks use a small corrugated plastic vent tube tucked into the top of the steel filler neck , but it often kinks & blocks fuel from entering the tank easily. Later trucks use a heavy plastic filler hose inside the steel vent neck, which allows MUCH easier filling.The necks are interchangeable, so it's a good upgrade for an old truck, especially if filling is becoming a problem. It also allows the use of a more modern gas cap..."
here it is by OUR GOOD FRIEND! Hard to Re-Fuel, Gas Station Pump Shuts-Off; "...There is a plastic vent tube inside the filler neck that often gets kinked..."
Source: by justshootme84 (Randy Z, Casual Mudder) at Ford Bronco Zone Forums http://broncozone.com/topic/19811-slow-to-fuel/
A
AdamDude04
Sorry..memory isn't as good these days! I'll read back at that old post as well. Now that it's summer, I want to tackle this
yo Adam,
No problem friend...Sometimes I get mixed-up... make that too much now...lol
That was a bad one on my part; I carried over a flame on my from another BroncoForum, the person there called me a clown!..lol
but better than a dude that threatened to hunt me and my fam down because I wrote almost the same thAng that I wrote to you...
gl!
kc.collins21
