trashman1980
- Joined
- Sep 4, 2005
- Messages
- 7
- Reaction score
- 0
i just bought an 83, i just put a new tank on and was tring to put the 3gal or so back in and it took for ever is there any thing i can do for this? thanks
Hi I have a 1990 and put a fuel pump in to find out that it was o.k. and I needed to replace the eec iv. now I have an idle problem that after it goes through the warm up cycle thr idle get really erratic never going higher than base idle but almost to the point of stall, I thought that maybe I put the fuel tanks vent valve in reversed.so you just put a new tank in, and you put 3 gallons in, or 33? its not going to be a really fast process, 33 gallons is alot of fuel to dump. if it was only 3 gallons, you definitely have a plugged tank vent somewhere. they are cheap and easy to replace
26922[/snapback]
i do not think it matters which way it facesHi I have a 1990 and put a fuel pump in to find out that it was o.k. and I needed to replace the eec iv. now I have an idle problem that after it goes through the warm up cycle thr idle get really erratic never going higher than base idle but almost to the point of stall, I thought that maybe I put the fuel tanks vent valve in reversed.Is it dirctional or not..its the only thing that I could have touched and have not checked yet.
Any idea.
Dan
27062[/snapback]
did you replace the sock in the tank with the filter? have you checked the fuel filter itself? also check your fuel pressure at the rail to make sure it's good. you could have got a bad pump.Hi I have a 1990 and put a fuel pump in to find out that it was o.k. and I needed to replace the eec iv. now I have an idle problem that after it goes through the warm up cycle thr idle get really erratic never going higher than base idle but almost to the point of stall, I thought that maybe I put the fuel tanks vent valve in reversed.Is it dirctional or not..its the only thing that I could have touched and have not checked yet.
Any idea.
Dan
27062[/snapback]
