So I just bought a 1990 full size Bronco from an older man.
1. The fuel tank is leaking a steady drip... so first question- will an F150 or F250 tank work on the Bronco? My local salvage yard has F150s and F250s...
2. Same question with the radiator cause mine has a small crack somewhere...
3. Lastly is the throttle body... it appears to have a new MAF sensor on it but it is not plugged in... when it is plugged in it takes off to massive high RPMs but then when I plugged it in, it cannot stay running without me nursing the gas... so, you guys think I need a new throttle body?
