Fuel system??
JDbroncoguy
Recently purchased a 96 bronco with the 5.0 in her. I've replaced the fuel filter and plugs already. Idles totally fine then when I go to give it gas to move it falls on it's face. I've seen some thing about cats clogging up. Never had a ford so maybe someone on here will have an idea o what it could be
Rons beast
Hey JD,
probably not the cats. That usually shows as poor high speed acceleration. Even if the CEL isn't on you should pull cods both KOEO and KOER.
Post any codes here.
First thing is a visual inspection of all vacuum lines and connections for the air intake. But a scan for codes gives the first indication of what path to take.
Good Luck
guilhermeknob
