My 89 bronco died yesterday, would not start again. When I tried to start it again it seemed to turn fine, but was missing spark or fuel. I started looking at the coil and it was delivering voltage. I pulled the line after the fuel filter and was getting nothing through it. I pulled both lines to and from the fuel pump and have gas to, but not through. I pulled the pump and was 2 secounds from sending the wife for a new fuel pump after she went to class that afternoon, when I thought I wanted to be sure that was the problem. I took to jumper wires, I had her hold the two ends to a battery, while i hit the terminals of the fuel pump with juice. The pump fired right off. Well with this, I went back down to my bronco and checked the voltage with the ignition switch turned over. I had 6.7 volts at the two leads for the fuel pump.
I then talked with a friend about the problem, he suggested that there might be a weak fuel pump relay, or a fuseable link that was partly fried. I looked in the handbook and read that there is supposed to be a fuseable link near the starter relay. I could not see one, does anyone have any advise about how to get this problem resolved? I already thought about splicing into a keyed power circuit sand running a new wire, but will only do that as a last resort. Thanks for any replies
