fuel pump STILL
Micah_86
OK MY FUEL PUMP IS OK AND WORKING BUT ITS NOT GETTING ANY POWER TO IT AND THE TRUCK WONT START... I DONT KNOW WHAT TO DO LOOKED FOR THE FUSES IN THE MAIN INTERIOR FUSE BOX AND THAT WASNT IT AND I CANT FIGURE OUT WHAT I NEED TO DO PLEASE HELP I HAVE NO TRANSPORTATION RIGHT NOW! THANKS A LOT! STILL CANT FIGURE IT OUT AND DRIVING ME CRAZY I LIVE IN FT WORTH TEXAS AND ANYONE KNOW WHERE OR WHAT I CAN DO? PLEASE HELP!!!
OK we need some more info here . You say the pump is ok and working ? How do you know that without power there ? . There are 2 relays on the drivers side mounted to the side of a big fuse box there . If they havent been changed before there is a gren one aqnd a brown one . I cant remember right now and Im at work so I cant look it up but one of them is for the fuel pump it is a normal thing for them to go bad . Also there is a fuse for the fuel pump in the dash panel fuse box . If the fuse is good more than likely the relay is bad . Some vehicles also had an inertia switch if it got bumped hard this switch disengages the fuel pump in the event of an accident . Make sure if you have one that it isnt tripped I believe theres a red reset button on the switch . Hope that helps . If you still cant figure it out Ill check with my buddy that works at ford he told me that 2 of the wires in the test port on the drivers side if jumped together will cause the fuel pumps to run ( pulls in that relay ) So if your still having problems Ill check with him and gt back to ya . :D /emoticons/[email protected] 2x" width="20" height="20" />
I believe thaty the inertia switch in your truck is under the dash on the driver side. It is a squarish device with two wires and a reset button on it. They have been known to go bad and drive people nuts trying to figure out what is goning on. also I believe that you have two fuel pumps in that truck, a low pressure pump in the tank and a high pressure pump outside the tank.
Also please only post your questions in one forum, thanks. :) /emoticons/[email protected] 2x" width="20" height="20" />
bronco89302
i have the same prob
i checked the inertia switch
replaced the fuel pump relay
i tested the eec relay and it apears good
and i tried the thing with the jumper to make the pumps come on
still nothing
they are not getting power
and to my knoledge there is not a fuse in the box for the fuel pump
there is one in the powere distribution box, but for some reason i dont have one
the hole dang box is gone
please help
JBronco
Jacksonville NC
Hey guys im having exact same problem it first happened about month ago the truck just died adn the fuel pumps would start up when i turned the key. I messed with it for a week i changed a relay that i though was fuel pump relay it was the grat and black relay it didint help then i took it to shop and he said it turned out to be computer relay wich is the brown relay and that fixed the problem. Now a week ago it shut off again so i assumed ill get another brown relay and fix it. well went to junk yard and yanked one off differnt bronco hooked it up and still nothing as far as i can tell there is 3 relays that look similar and differ in color the brown is computer relay and im assuming the gray and black is fuel pump relay also there is a green relay i havent messed with mine because i dont know what it is for im thinking of getting another green relay from Jyard also and hope it works i have checked both my pumps and they both work they just arent getting power i checked all my fuses and inertia switch so only thing left i havent changed or checked is that green relay i would appriciate it if somone could please tell me what that relay is for. Thanks
bronco89302
supposadly its not the comp relay
i have a mechanic friend who is getting me a special wiring diagram
so i can chase the prob
the prob is not no power just lack of power
and if there isnt a certain amount it wont get past the relay
guilhermeknob
