B-Co Kid
- Joined
- Oct 14, 2010
- Messages
- 235
- Reaction score
- 8
1987, 351w, c6 trans, no EEC
I initially had problems with the fuel gauge bouncing around and could not figure out why. So when I began restoring the B-Co I replaced the 33 gallon tank and used an aftermarket fuel sending unit bought from broncograveyard. Now, when the tank is near empty, the fuel gauge reads at a half tank. When the tank is full the gauge reads empty. Consequently broncograveyard has updated their website to say that some applications will read reversed. Nevertheless I now know that the sending unit is not the correct ohm rating and the empty/full should be reversed. My question is, can I use an aftermarket gauge that matches the sending unit in the tank? Aftermarket gauges require 12v for the lighting and a 12v from ignition, however, the original setup only supplied 5v to the sending unit. Do I only need a fuel level gauge, or will I have to get another sending unit and gauge kit??
