Fuel Filler Neck
TennesseeBroncBoy
Fort Walton Beach, FL
I need to install a new fuel hose(longer than stock) from my filler neck to my tank. Is there a certain hose material I should be using especially for this, or will any sort of hose work? Maybe like a radiator hose material or something? (Just installed new Daystar body mount bushings and 3" lift is almost done.) Fuel hose barely fits on there now(1/2" connected on filler tube) Any suggestions are well welcomed. Thanks guys.
bluesman17
Spam Terminator
South Bend, Indiana
Youre in tricky business, i had a straight tube when my ripped and it took like 10 minutes to put in a couple of gallons. that may just be me but if its secure i would leave it personally.
Go to your local friendly auto parts dealer and see if they have fuel rated hose in the size you are looking for. I wouldn't use any hose that is not rated for fuel as it will deteriorate and load the fuel up witha lot of crap. Like Bluesman17 said you may also need a longer vent tube in order to keep the filling process reasonable.
wtfdissux
Buffalo, NY
dont know what parts houses are in your area but here napa has the correct diameter neoprene hoses in 6 foot lengths
