i have a 1990 bronco with six inch lift and a c-6 trans and 208 transfer case. my front shaft wont bolt up. it is rubbing against crossmember. what is a fix for this?
trimming the xmember. another trick you can try is to flip the orientation of the driveshaft around. this works for some and not for others. if you do trim the x member, be sure you weld a tunnel of some sort to maintain rigidity of the structure
