can anyone tell me the easiest way to remove rivets from the radius arm drop braket ? i am installing a 6" lift and that is the only thing holding me up. thanks.
I just removed a whole lot of them on my Bronco, I tried every way I could think of, the easiest quickest way I found was center punch, drill with 1/8 drill bit and then a 7/16. use the best bits you can get your hands on, they are worth the money. I used cobalt bits i think they were called and they went through like butter
Not to counter yardape, but i've found taking a cut-off wheel and cutting an x in the center of the head and then taking a good sharp cold chisel and hammer that they come out a little easier... /emoticons/[email protected] 2x" width="20" height="20" />
