Ford T-18 Transmission Conversion
W
Wayne
Guest
I've found a Ford T-18 4 speed that I believe is out of a 2wd truck. It has a short tailshaft with the bolt on yoke on the output shaft. I want to convert an early Bronco with a V8/ 3 speed manual with Ford Dana 20 transfer case. Will this T-18 work with this output shaft?
I understand that I have to get an aftermarket adapter between the T-18 and the Dana 20 with the correct bolt patterns. Do I retain the factory gear, bearing and shaft from my V8 Intermediate Housing to put in the aftermarket adapter?
Thanks,
Wayne
drilldawg
If you find that you can not use this tranny for what you want could you please contact me. I ve been looking for a couple of T18s for our drill rig. Also if you know where to locate other units would you contact me.
509--385-7466 or [email protected]
S_bolt19
Colorado
The T-18 will work just like the NP435. You still need to get the intermediate housing from a 6 cylinder EB to replace the one you currently have between your trans & x-fer.
79' Buckin Bronco
