So i have a 1980 c6 transmission that was leaking oil around the modulator valve (Bad O-ring) the stripe had long since worn off so i just bought one with a black stripe cause i had always been told that the stripe didn't matter cause they're all adjustable and the black stripe was most common. Is this true? And if so how to i adjust it and where? i'm guessing its the ***** where the rubber hose connects to the valve but i'm not sure. Also the its been apart for a couple on days and when i went to put it back together i went looking for the modulator valve pin and there it was, GONE, and i can't find it, i know they come in different lengths so can i just put a different pin in it and adjust the modulator valve till it shifts right? Thanks.
