flywheel
beefy85
dallas, Tx
last week i replaced the flywheel on my 85 bronc, but yesterday it started doin what it was doin before. when you start it you can hear where it sounds like it is missin, and sumtimes it will stop in one stop and the starter will just turn what do yall think is goin on cuz im freash out off ideas. thanx if yall need a better explanation yall can call my cell its 806-664-6672 after 2:30 centeral time
Id say the starter I had one of those gear reduction ones from jegs motor kicked back and sounded like it ripped all the gear teeth off the flywheel I even bought a new flywheel and replaces it only to find out it was doing the same thing must have broken something in the oneway clutch in the bendix . Put another starter on it and good to go . :D /emoticons/[email protected] 2x" width="20" height="20" />
beefy85
dallas, Tx
its a new starter form advance. and when it dosnt catch i just get under the hood and turn the motor over with the belt and then itll start right up
HMMMMMM youll have to pull the inspection cover and inspect all the teeth to be sure there on there and if so I would then try another starter just because . :D /emoticons/[email protected] 2x" width="20" height="20" />
