Floor Shift Conversion
gravelgerty
help, cant seem to find any info on a floor shift conv. for a 6 cyl. also need the e-mail address for james duff ent.
Bronco Rick
Deer Park, Texas
James Duff does not give their email address, on their web site you click on CONTACT US and it will take you to a form where you fill in some info and submit it. I am sure that once you got a reply from them in your email then you could find out what the actual email address was by looking at the properties of the FROM box on the email. Sorry I do not know much info on a floor conversion for a 6 cyl. I have done one on a 8 cyl and it was actually pretty simple, I would not think that doing it on a 6 would be too much more difficult. Wild Horses web site says that their conversion is designed for a V8 but can be modified to fit a 6.
66akbroncman
I did this conversion myself a few months ago using the James Duff kit. The only thing you have to do is shorten both shift rods I think 2.5 inches. after that everything just bolts right up. It was a real easy conversion and definitly worth it. Good Luck if you run into any problems let me know and I will try to help.
79' Buckin Bronco
