Finally read codes
firelt90bronco
Ask me about my job
northeast
I just finished reading the codes for my 1990 Bronco. Can anyone tell me what they are and what would cause all these? They read as follows:
KOEO
31
KOER
21
31
41
52
25
bobstrat
beautiful trenton, n.j.
2 Digit Codes
System OK
Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low) - ISC
13
(O)
ISC did not respond properly (extends to touch throttle then retracts for KOEO) - ISC
Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too high)
(M)
ISC sticking, open ITS circuit or TP sticking
14
Ignition pickup (PIP) was erratic - Ignition Systems
E4OD Transmission diesel RPM sensor - Diesel RPM sensor
15
(O)
No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure)
(M)
KAM (pin 1) was interrupted (was battery disconnected ?)
16
1 9L & 2 5L - Throttle stop set too high - IDLE or Idle Set Procedures
2 3L - RPM's too low - IDLE
(O)
Electronic ignition - IDM circuit fault - Ignition Systems
17
1 9L & 2 5L - Throttle stop set too low - IDLE
18
Check base timing & advance function - Timing Tests
(M)
Ignition TACH signal erratic - Ignition Systems
Spark Angle Word (SAW) circuit failure (1 9L SFI)
19
(O)
No Vehicle Power (pins 37 + 57) or bad PCM VPWR Diagnosis
Erratic idle during test (reset throttle & retest) - Idle Set Procedures
Electronic ignition Cylinder ID sensor/circuit problem - Ignition Systems
21
Engine Coolant Temperature (ECT) sensor out of range - ECT
22
MAP (vacuum) or BARO signal out of range - MAP
23
Throttle sensor out of range or throttle set too high - TPS
24
Intake Air Temperature (IAT) or Vane Air Temperature (VAT) sensor out of range - IAT VAT
25
Knock sensor not tested (ignore if not pinging) - KS
26
Mass Air Flow (MAF) or Vane Air Flow (VAF) out of range - MAF VAF
Transmission Oil Temperature (TOT) sensor out of range, Transmissions
27
Vehicle Speed Sensor problem - VSS
28
Vane Air Temperature (VAT) sensor out of range - VAT
2 3L w/Electronic Ignition - Cyl ID, IDM low or right coil pack failure - Ignition Systems
29
31
(O,R,M)
EVP - EVP signal is/was out of range - EVP
(O,R,M)
EVR - EVP signal is/was low - EVR
(O,R,M)
PFE - PFE signal is/was low - PFE
32
EVP - EGR not responding properly during test - EVP
(O,R,M)
(R,M)
PFE - PFE shows low pressure, EGR not seating or memory, not seating intermittently - PFE
33
(O,M)
ALL - EGR did not open/ respond during test or if memory code, did not open intermittently - EVP EVR PFE
34
EVP - EGR did not respond properly during test - EVP
(O,R,M)
EVR - EVP sensor is/was high - EVR
(O,R,M)
PFE - PFE sensor is/was out of range - PFE
EVP - Engine RPM's too low to test EGR system - EVP
(O,R,M)
EVR - EVP sensor signal is/was high - EVR
(O,R,M)
PFE - PFE sensor signal is/was high - PFE
38
Idle Tracking Switch signal was intermittent - ISC
39
Transmission Torque Converter clutch not engaging - Transmissions
41
System lean - Fuel control
(M)
System was lean for 15 seconds or more (no HO2S switching) - Fuel control
42
System rich - Fuel control
(M)
System was rich for 15 seconds or more (no HO2S switching) - Fuel control
43
HO2S sensor not reading (run at 2000 rpm's for 2 minutes and retest - check for HO2S switching)
(M)
Was lean at WOT for 3 seconds or more - Fuel control
44
AIR system inoperative - Air Injection
45
AIR not Diverting (AIRD) - Air Injection
Electronic Ignition - coil primary circuit failure - Ignition Systems
46
AIR Bypass (AIRB) not working - Air Injection
Electronic Ignition - primary circuit failure coil 2 - Ignition Systems
47
Low flow unmetered air (check for small vacuum leaks, injector o'rings, gaskets etc )
E4OD transmission 4x4 switch/circuit problem - Transmissions
48
High flow unmetered air (check for large vacuum leak, inlet hoses etc )
49
Electronic Ignition - spout signal circuit problem - Ignition Systems
Transmission 1/2 shift problem - Transmissions
51
Engine Coolant Temperature (ECT) sensor signal is/was too high - ECT
52
Power Steering Pressure Switch/circuit open - PSP
Did you turn wheel during test ?
53
Throttle Position sensor too high - TPS
54
Intake Air Temperature (IAT) or Vane Air Temperature (VAT) signal high - IAT VAT
55
No or low (under 7 5 V) Key Power to PCM pin 5
56
Vane Air Flow (VAF) or Mass Air Flow (MAF) sensor high - VAF MAF
Transmission Oil Temperature sensor too high - Transmissions
57
Intermittent in Park/Neutral/ Switch or Neutral Pressure switch circuit - PNP or Transmissions
58
Idle Tracking Switch (ITS) signal problem ISC
Vane Air Temperature (VAT) sensor out of range or open - VAT
59
AXOD 4/3 circuit fault - Transmissions
3 0L SHO - Low speed fuel pump circuit problem - Power / Fuel Pump Circuits
Transmission 2/3 shift problem - Transmissions
61
Engine Coolant Temperature (ECT) sensor is or was too low - ECT
62
AXOD (KOEO only) 3/2 circuit short to ground - Transmissions
AXOD (KOEO AND KOER) 4/3 circuit failure - Transmissions
E4OD excessive converter clutch slippage - Transmissions
63
Throttle Position Sensor (TPS) signal too low TPS
64
Intake Air Temperature (IAT) or Vane Air Temperature (VAT) signal low or grounded - IAT VAT
65
Check intermittent HO2S (signal or ground) - Fuel Control
E4OD truck - cycle OD cancel switch after engine ID is received - Transmissions
1984 3 8L ONLY - O, M Battery voltage high (check for electrical system overcharging)
66
Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - VAF MAF
Transmission Oil Temperature (TOT) signal low (possibly grounded) - Transmissions
67
Park/Neutral circuit fault - PNP
Transmission Manual Lever Position (MLP) sensor circuit - Transmissions
(M)
Intermittent Park Neutral Position (PNP) sensor fault - PNP
68
Idle Tracking Switch (ITS) circuit (possibly grounded) - ISC
Vane Air Temperature (VAT) sensor out of range or grounded - VAT
3 8L AXOD -Transmission Temperature Switch (TTS) open - Transmissions
Electronic Transmission - Transmission Oil Temperature (TOT) sensor was overheated -Transmissions
69
AXOD transmission (O) 3/2 switch closed (possible short circuit) - Transmissions
AXOD (M) 3/2 switch open (poss short to power) - Transmissions
E4OD 3/4 shift problem - Transmissions
70
(M)
3 8L AXOD - Data link to instrument cluster fault Service any other EEC codes, erase memory and retest If code is still present refer to instrument cluster diagnosis manual
71
(M)
1 9L TBI, 2 3L TBI, 2 5L TBI - ITS signal was grounded when throttle should have been opening ITS-ISC ISC motor problem or Idle Tracking Switch (ITS) signal wire shorted to ground - ISC
(M)
1 9L MFI - PCM re-initialized Possible electrical noise, case ground or intermittent VPWR problem - VPWR Diagnosis
(M)
3 8L AXOD - Data link to instrument cluster fault - See code 70
72
No MAP or MAF change in "goose" test - retest, check for frequency or voltage change - MAP MAF
(M)
1 9L MFI - VPWR circuit to PCM was intermittent - VPWR Diagnosis
(M)
2 3L T/C - PCM re-initialized Possible electrical noise, case ground or intermittent VPWR problem - VPWR Diagnosis
(M)
3 8L AXOD - Message center data link circuit fault - See code 70
73
(O)
Rerun test, if 73 is still output replace TPS
No Throttle Position Sensor (TPS) change in "goose" test Must get at least 25% throttle rotation - TPS
74
Was brake depressed after engine ID was received ?
Brake On Off (BOO) signal open or short to ground - BOO
75
Brake On Off (BOO) signal shorted to power - BOO
76
Vane Air Flow (VAF) did not respond to "goose" test - VAF
77
System did not receive "goose" test - see TESTS
78
(M)
VPWR circuit to PCM was intermittent or the PCM is bad VPWR Diagnosis
79
A/C is on or pin 10 is shorted to power
81
Boost control solenoid - Solenoids
AIRD solenoid - Solenoids and Air Injection
3 0L SHO - Inlet Air Solenoid - Solenoids
82
2 3L TC - Fan Control wire shorted to ground - A/C and Fan Circuits
AIRB solenoid - Solenoids and Air Injection
3 8L SC - Super Charger Bypass Solenoid - Solenoids
83
High Electro Drive Fan circuit fault - A/C and Fan Circuits
EGR Control solenoid - Solenoids
3 0L SHO - Low Speed Fuel Pump Relay circuit - Power / Fuel Pump Circuits
84
EGR Vacuum Regulator - Solenoids
EGR cutoff solenoid - Solenoids
EGR Vent solenoid - Solenoids
85
2 3L T/C Automatic - 3/4-4/3 Shift solenoid - Transmissions
CANP solenoid (ALL 1989) - Solenoids
(M)
1 9L MFI - System has corrected rich condition - Fuel control
86
2 3L or 2 9L Truck - A4LD 3/4 shift solenoid - Transmissions
(M) 1 9L MFI - System has corrected lean condition - Fuel control
87
(O)
Fuel pump circuit fault (check inertia switch) - Power / Fuel Pump Circuits
Vehicles with 2BBL carb - Temperature Compensated Accelerator Pump Solenoid - Solenoids (M) intermittent in fuel pump primary circuit - Power / Fuel Pump Circuits NOTE: On some Escorts with automatic seat belts this code is normal IN MEMORY due to the wiring
88
Throttle Kicker Solenoid - Solenoids
Variable Voltage Choke relay circuit fault - VVC
Fan Control circuit fault - A/C and Fan Circuits
A4LD - Converter Clutch Override solenoid - Transmissions
Electronic Ignition - IDM, DPI or spout circuit fault - Ignition Systems
89
AXOD Torque Converter Control solenoid circuit - Transmissions
Exhaust Heat Control (heat riser) solenoid circuit - Solenoids
91
(R, M) System running lean - Fuel control
Transmission SS 1 circuit/solenoid problem - Transmissions
92
System running rich - Fuel control
Transmission SS 2 circuit/solenoid problem - Transmissions
93
(O,R)
Throttle linkage binding or bad ISC motor ISC HO2S not reading Fuel control
Transmission TCC circuit/solenoid problem - Transmissions
94
95
(O)
Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits
(M)
Possible bad fuel pump ground or open between fuel pump and pin 8 at PCM (Fuel Pump Monitor signal) - Power / Fuel Pump Circuits
96
(O)
Fuel pump monitor circuit shows no power - Power / Fuel Pump Circuits
(M)
(Service 87 code first if present) Fuel pump relay or battery power feed was open - Power / Fuel Pump Circuits
97
E4OD OD cancel light circuit failure - Transmissions
98
Did not pass KOEO yet (Get 11 in KOEO first)
Transmission EPC circuit/solenoid failure - Transmissions
99
ISC needs to learn (Let idle for 2 minutes, Erase memory and retest)
bobstrat
well the koer
21 coolant temp sensor is out of range- i would take that to mean your sensor is beat.
31 (O,R,M) EVP - EVP signal is/was out of range - EVP
(O,R,M) EVR - EVP signal is/was low - EVR
(O,R,M) PFE - PFE signal is/was low - PFE
i have no idea what 31 means.
41 system lean - fuel control bad fuel pressure regulator maybe? something else that would cause a lean condition? maybe tied in with the 31?
52 Power Steering Pressure Switch/circuit open - PSP
25 Knock sensor not tested (ignore if not pinging) - KS
bobstrat
evr and evp now you got me thinking about it, arent they the little doo dads by the ignition coil, part of the vacuum tubing stuff, the two little black plastic, i dont know if theyre vacuum switches or what, but they have the round caps on them?
F
firelt90bronco
Ask me about my job
northeast
Could the lean mix be caused by the distributor being turned too far? I had to pull the distributor to install the ICM.
Timing doesnt have anything to do with the lean condition. I'd focus more toward the fuel pressure regulator. Or the possibility of plugged/restricted injectors
wtfdissux
Buffalo, NY
is the O2 sensor old ....could be sending a false lean code
also the ect may cause this by reporting incorrect temp and sending into closed or open loop at the wrong time
and the solenoids by the coil are the tab and tad solenoids and on some the egr solenoid
main thing is to repair/ diagnose and repair them in the order that they come up in and clear them after each repair is made then drive and see what happens as the ford obd1 had a good ability of compensating for problems and would cover for bad info ....meaning that one code will cause the pcm to do something based on all other signals sometimes sending "false codes " that will only go away when the real code is fixed so start with hard or constant codes first then do them in the order they come in
F
firelt90bronco
Ask me about my job
northeast
Tomorrow I'll take the o2 sensor out and clean it and then take the vacuum line off the fuel pressure regulator.
wtfdissux
Buffalo, NY
would rec changing the ect while at it when they go can cause real bad mpg and cold weather running and try cleaning the IAC and throttle body and egr body and tube really good might want to try the sea foam bit if it runs long enough to burn it off
am gonna take a quick look at some of my notes I remember something about the evp/pfe also have fun on the regulator they are a pain in the a&* with upside down allen or torx head and not much room to use anything but a bit in a wrench
is the O2 sensor old ....could be sending a false lean codealso the ect may cause this by reporting incorrect temp and sending into closed or open loop at the wrong time
What he says makes a ton of sense, check that out for sure
wtfdissux
Buffalo, NY
EGR Valve position sensor
egr/evp is attached to the egr valve to produce a signal indicating to the EEC-IV system the exact position of the egr valve
check:
disconnect theelectrical connector on the evpsensorand check for reference voltage from the computor with the key on but not runningthere should beapprox. 5.0 volts
next check the resistance of the evpsensor. working on the sensor side check the resistance of the evp and vref. it should be approx. 5,000 ohms.
now apply10 in.hg.of vacuum and checkthe resistance it should be approx. 100 ohms watch for a decrease in resistance as vacuum is applied
yes this may also cause the 41 code along with the ect code
if problems are on the wire side check for breaks etc. if on the evp side replace the evp and thouroly clean the egr valve or replace it clear codes and proceed to next if they reappear after test drive (might need to drive for a few days)
I agree w/wtfdissux, on the EVP, good job man! Some info to complement his info from my notes; the evp works like a throttle position sensor, going from high resistance (5500 ohms) when the EGR valve is closed to low resistance (100 ohms) when it is open
some more info on the DTCs;
21 ECT (Engine Coolant Temp) out of range. Coolant is less than 50degF for KOEO, or less than 180 deg F for KOER, or greater than 250degF for either. If coolant temp is in proper range, suspect ECT sensor. (It won't be, for KOER tests on cars that have a 160degF thermostat)
52 PSPS (Power Steering Pressure Switch) circuit open. Suspect PSPS, harness, or as someone wrote (can't see his identity or comment now in the "Reply" mode); 52® Steering wheel not turned during test or PSPS problem
31 info by Henry G; This code could be caused by several different factors
If the pintle position sensor (Ford calls it the EVP sensor) is shorted or open, you could have a code set.
If the EGR valve becomes carboned up and does not seat fully, the EVP sensor gives a high reading and a code is set.
If the diaphragm of the EGR valve is bad, then it, too, is flagged.
The fix
On Fords and Mazdas, the only sure fix is to replace the sensor and valve as an assembly. Sometimes you can get temporary relief by filing down the pintle sensor stem to lower the sensor return voltage to specs. Or you could add a thicker gasket between the valve and sensor. You can spend a lot of time trying to capture the intermittent failure in the act. This is not recommended. The codes are rarely false. Note that there are two interchangeable sensors; one is gray and the other is black. Key-on-engine-off (KOEO) voltage for the gray sensor is 0.40 volt and for the black sensor is about 0.83 volt. Don't mix them up, or Code 31 won't go away.
41 Check for leaking fuel injector and/or excessive fuel pump pressure
what else did i miss? can't see your DTC List post now, so will look @ your original post that started this later.
F
firelt90bronco
Ask me about my job
northeast
Okay, the fuel pressure at the Schrader valve is 33 with a new pump and filter. I suspect the fuel pressure regulator may not be open all the way to deliver adequate pressure.
wtfdissux
Buffalo, NY
for 52 PSPS (Power Steering Pressure Switch) circuit open was the steering wheel turned when promted and does your truck have a presure switch on the presure line but honestly I would not wory so much on that until the other ones are gone
also check fuel laekdown by attaching presure gage start engine then shut off record the number and leaving the gage hooked up wait an hour or so and see if it droped
F
firelt90bronco
Ask me about my job
northeast
I just cleared the codes and no check engine light!!!! I took her for a ride around the block and it seems fine except for a slght pull from a low tire. Now all thats left is time it completely and its great again!
Gasman80
