Fi On 84
stang96gts
What do I need to put FI on my 84 302 bronco?? Where can I get and how much $$?
There are several ways you can go to get fuel injection. TBI (throttle body) or MPFI (individual cylinders) are available from Holley, Edelbrock and others for about $1000-$2000 parts and labor. Or you can swap the parts from a used EFI motor that is the same size as yours. You will need new fuel lines and a high pressure fuel pump, computer, wiring harness and the intake. Even the TBI system from GM motors will work. It ain't cheap!!!
Txquadhunter
N. Texas
cheapiest and easiest way would be to find a donner 86+ bronco or truck with a EFI 302 or 351w that way you'll have everything at hand on a similer truck to do it. I posted a link to a helpful site in the post 300 to EFI
bfisher1970
